VESSEL2020
Somewhere in Space
Anyone lookin' to dump their MIDIizer...???
The specific model is MTS-1000
Not the ATS-500
Not the ATS-500
Will a JL Cooper Data Sync work..?
Can I sync 2 tape machines & hardware sequencer with it?
I'm looking for the functions of the MTS-1000,..if it will do this,..then yes
MTS-30 - MIDI to FSK translator with Song Position Pointer - Provides MIDI sync for a single tape machine via FSK or SPP, with the tascam acting as the master. The MTS-30 plugs into the the in/out on track 8. Then it has MIDI ports for integration into your MIDI setup. It seems to be no different than any other MIDI/timecode interface. It doesn't utilize the 'Accessory 2' port.
MMC-100 - MIDI Machine Control via Tascam Serial - works in much the same way as the MTS-30 but implements full MMC protocol. Thus the tascam can be the slave or the master. In addition to using track 8 for timecode, the 'Accessory 2' port is used to maintain correct tape speed during playback to maintain sync. If you bought one of these for each deck, and used a MMC-based tranport master (like a sequencer, for example) you could use both decks at the same time.
ATS-500 - Two Machine Serial Synchronizer - This box uses one tascam as a master and one tascam as a slave. It has two 'Accessory 2' ports, one for each tape deck, and a bunch of I/O for the timecode on both machines, plus external timecode inputs (to sync both machines with a video deck or master timecode generator for example). Doesn't have a MIDI interface built in. Keep in mind that you'll only have 14 total tracks, since the timecode uses one track on each machine.
MTS-1000 - MIDIizer: Two Machine Serial Sync w/MIDI - Again, using one machine as master and one as slave in a MIDI environment. This seems to be the ultimate solution to everything. It does everything the ATS-500 does, plus includes MIDI.
I don't know about the OP's deck, but the 238 is slaved via the RS-232C serial port. If you're wanting to slave a MIDI sequencer to the tape deck, a cheaper alternative would be:
(1) MOTU MIDI Timepiece - prints SMPTE to a tape track and converts SMPTE to MTC for controlling a MIDI device. The JL Cooper unit probably works about the same way.
(2) Roland MC series sequencer - prints FSK to a tape track and chases it to control other MIDI devices.
Those Tascam boxes are rare and expensive. What kind of machines are you wanting to sync?
Tascam 38 & TSR-8 along with hardware sequencer. (all three sync'd)
Sorry,..my internet connection acts up when it's raining,..and it's raining pretty hard here right now.So at least one of the tape decks will have to be slaved to one of the other two devices. Do the 38 and TSR-8 have a D-shaped serial port on them?
Well, it has smpte and midi ports..Maybe it will..Maybe someone here could verify it.If so, I have one for sale...
It's been a long time since I've done any separate tape sync'ing but if I remember correctly, you'll lose two tracks ( one stripe tone track on each machine) in order to sync'em..
Well I guess in this case, you'll lose three tracks then..(lol)..Good luck..!Yes my friend,..I'm aware of that. That's not a problem.
Just tryin' to figure a way to sync up all 3 together.
I have backing tracks that I'd like to sync with my sequencer,...but I need both machines sync'd...and I just figured from what I've read, that the MTS-1000 is the be all end all to what I would need. Though, I could be wrong.
Thanks,Well I guess in this case, you'll lose three tracks then..(lol)..Good luck..!
Thanks,
I tried to find a manual for the JL Cooper Data Sync to see the features of what it can do,..but no luck.
Do you know of a link so I can check the specs for myself?
What exactly do you need to know about the MTS-1000? I've got one (for my TSR-8) and have the manual.
