Kingofpain678
Returned from the dead
Here is the stock schematic of my amp
http://bestnetworx.com/uploader/files/52/Peavey Windsor SCHEMATIC.pdf
Here are the mods in schematic form -
Pre mod
Uploaded with ImageShack.us
Power section mod
and finally a list of the mods to be done:
The easiest way to work on this amp is to label and remove all of the wires and work on the PCBs from the bottom (they're single sided boards). Use solder wick and a low wattage iron and the parts are easily removed. Note: The ribbon cable that connects the preamp and power amp PCBs does not have to be removed. Try to avoid damaging the parts that you remove. Some of them can be used for the mods.
****CAUTION***** There are no bleeder resistors on the power supply caps Drain them before proceeding.
Preamp
1.) Jumper C2
2.) Add 1nF cap from VR1 "w" to VR1 "h"
3.) Remove R13
4.) Change R4 to 10k
5.) Remove C5
6.) Jumper R14
7.) Replace R5 with 820 ohm
8.) Remove C28
9.) Remove C18
10.) remove R56
11.) Remove R70
12.) Jumper from V2-1 to V2-7
13.) Replace R21 with 100k
14.) Remove C41
15.) Jumper R65
16.) Remove C6
17.) Jumper from V2-8 to the R3 / R36 junction
18.) Remove R36
19.) Replace R3 with 33k
20.) Replace C24 with 470p
21.) Replace C13 with 22n
Power amp
1.) Replace R45 with 100k 1W
2.) Connect a 3.3n cap across R45
3.) Replace R41, R42, R43, and R44 with 1k 5w
Power supply
1.) Connect a 330k across C10 (bleeder)
2.) Connect a 330k across C12 (bleeder)
R59 (400 ohm 10w ) should be replaced with a choke.
So, this is supposed to JCM800-ize my amp. And, this amp is cheap enough that I could not only mod this one but also buy another one and keep it stock.
So, here are my issues... I have no idea where to buy the pieces I need to mod this amp, if someone could help me out with that, that would be great.
Next, I don't know what I'm doing BUT my buddy is an electrical engineer and agreed to help me out with this. I know basic soldering and all that and he knows the technical side so this would be a joint effort.
So, if anyone with any electronic smarts could point me in the direction to get these parts and/or let me know if they have any objections to the mods listed - please let me know
Pre mod
Power section mod
Preamp
1.) Jumper C2
3.) Remove R13
5.) Remove C5
6.) Jumper R14
8.) Remove C28
9.) Remove C18
10.) remove R56
11.) Remove R70
14.) Remove C41
15.) Jumper R65
16.) Remove C6
18.) Remove R36
Power amp
Power supply
