T
TexaCali
Hello,
I've decided to record my son's middle school band and produce a CD for a school fundraiser. The school also has an orchestra which will be recorded separately. Problem is I have no experience recording large "classical" performances. Rock bands, small ensembles, etc, yes, but nothing like this.
I have "OK" equipment, nothing high end:
Mics: AT4040, matched pair of NT5's, and a bunch of "workhorse" Shure mics (older PE series, but similar to SM57 and SM58)
AI: M-Audio Fast Track Ultra 8R
Analog: Mackie CR1604-VLZ (I use the pre's on the board, then go to the AI "pre eq and fader"). I also have a HBB CD recorder for stereo backup recording, plus the usual compressors and time delay effects that only get used with live sound applications.
The recordings will be done in the band rehearsal room, which is a proper band room, tiered floor, lots of non-parallel surfaces, and very "quiet".
My thought is to place the NT5's as a stereo pair (X-Y, ORTF, A-B pair?) behind and above the conductor and use my remaining mics to fill in where needed. Anyone done something similar? What instruments are most likely to give trouble and require supplemental mics? Any tips to speed the learning curve appreciated.
BTW - I should have a chance to make some test recordings a few weeks before the real deal, so I can experiment a little...but not too much.
Tips and pointers greatly appreciated.
