GarrenKeith
hi guys. i need to be able to run fl studio, many plugins inside fl, and monitor an incoming signal with lowest latency as possible. what kind of desktop would i need to do this? will i need a quad core? please help. thanks!
What's Your Budget?
--Paul
Here is the deal. If FL Studio does not support quad core then get a cheaper dual core that has the highest clock speed you can find. If it does support quad core then get high highest quad you can find and afford. Let me explain, if you compare a Quad Core CPU with 2.5 ghz cores vs a Dual Core with 3.2 ghz cores, the Dual core will run software that is not quad core supported faster.
how does that work?
i'm not arguing, but, in windows can you not select certain cores for system only, and certain cores for apps......
surely that'd result in a faster system all round?
