T
talontsiawd
Ok, i found they are older reveal's. How would they compare to those listed above?
Blue Sky offers smaller systems (EXO and MediaDesk). MediaDesk will still pretty much give you the same low end and even, quick response (typically an advantage of acoustic suspension systems over ported ones) in a smaller space, but both smaller units lack the very nice Vifa tweeter.
Just thought I would chime in...
As the physical dimensions of a room get smaller, such as comparing a dubbing stage (30,000 cubic feet) to a typical control room (3000 cubic feet), the acoustic conditions change as well. The biggest change occurs at low frequencies, which in a large space is an issue relating to low frequency reverberation time. When you move into a smaller studio, the main acoustic factor at low frequencies is room modes, or standing waves.
In an AES paper by Louis D. Fielder of Dolby Labs ["Subwoofer Performance for the Accurate Reproduction of Music," Journal of the Audio Engineering Society, vol. 36, June 1988], it was demonstrated that smaller sealed rooms, such as the typical music studio, exhibit a 12 dB per octave gain below 30 to 35 Hz (this typically occurs below the lowest room mode). This 'room gain' response perfectly matches the sealed box response of our subwoofers (-12dB per octave roll-off, below their cut-off frequency), allowing for incredible in-room low frequency extension, down to below 20 Hz in many cases. Compare this to a typical ported or passive radiator roll-off of 24 dB per octave - or greater, and you can see why we prefer this design for small room monitoring applications.
For more information, please follow this link:
http://www.abluesky.com/asp/news/newspage.asp?id=75
I hope this helps...
Cheers!
I am going to get brutalized here, but I suggest taking a look at some used NS-10's. I got my first set by accident when a guy told me he bought his, hated them, hardly used them and would sell for $200. This happened while I was saving for Event 20/20's. I grabbed them and have not looked back. In fact I recently purchased another pair.
I power them at on location with an old SS Harman Kardon amp and in my overdub room with an old Denon consumer amp. I am very happy with the results.
Thanks for that explanation. 3000 cu/ft seems more reasonable. I just can't imagine trying to mix in a less then 2000 cu/ft room just for the sake of the sub considering all the other problems a room that small can cause.
In the process myself, with about the same budget. Found reviews of most of the ones mentioned below on the Soundonsound site, worth a read to get started. The HR824/HR624 seems to have been updated to Mk2 recently and kind of a personal favourite of the reviewer, but Adam Audio A7, Dynaudio BM5, Tannoy Reveal 8D and Event TR5/TR8 are also listed. Site policy don't allow me linking, but a search will find these easily.
the woofers should be replaced every year or so
The rubber surrounds start to stretch. That's based on every day use. I forgot most people probably don't use them that often. If you're only using them on weekends then they can last quite a bit longer.what the hell for??
The point is that as the room volume increases, the system capacity of the monitors needs to increase in order to maintain adequate maximum SPL across the full frequency range. Bigger rooms need bigger drivers, boxes and amps to maintain that performance level. Monitor makers sell systems of all sizes to work in different rooms. You could always buy a bigger system and use it in a smaller room, but you will be spending more than you need to.
Nearfields are nearfields. You wouldn't expect them to fill a large room but there's no reason they wouldn't work properly in their usual sweetspot even outdoors. I can understand how Blue Sky is using a small room's modal tendancies to exaggerate the sub's bass response, just like sticking a sub in the corner, but the idea that you need bigger speakers just to mix in the nearfield seems like overkill to me.
