Hello,
I am afraid I need a hand with some understanding signal levels.
I was essentially searching for reviews to couple Focusrite Scarlet 2i4 and Rode Procaster Dynamic Mic. It turns out that Focusrite is not powerful enough for the mic. I found a website The Rode Procaster Levels are Too Low & I Need More Gain! where someone complains about low level of sound using aforementioned configuration. I can follow the excplanation in general but can't figure out a few details. This is a direct citation of the part I don't understand:
I can't figure out, using this particular configuration, where 0.16 vols comes from and how it happens that number is an output from the interface. I do understand that in order for two items to work, the audio interface should be more powerful, so that output of a "line level" of a signal from the interface should be about 1.2V. I guess this has something to do with different signals levels I just read on Wikil
So, person answering the question says that speech is around 74dB. I take it as a fact. The difference between reference level 94dB and 74 dB is 20 dB. That makes:
Therefore, considering speech level, signal this particular mic would provide to interface is `1.6mV / 10 = 0.16mV`. Because Focusrite amplifies a signal by 50dB, that is:
the interface's output signal would be just 0.16mV * 316 = 50.6 mV! This is completely different from 0.16V. That's not even close and I don't know what I am missing.
Thanks in advance.
The Focusrite Scarlett range, including the 2i4, is capable of producing a gain of 50 dB max compared to the 65 dB max on the Presonus AudioBox. That extra 15 dB would more than solve your problem. If you figure that you're capturing your speech around 74 dB with the mic around 6 inches to a foot away, that 50 db of gain is only going to push the signal to around 0.16 volts. The preamp is meant to boost the signal to line level around 1.2 V. You're still drastically below, but 10 more decibels of gain could push you to 1.6 V, well above line level.
Code:
20 = 20*log10(x) => x = 10
Code:
50 = 20*log10(x) => x = 10^2.5 ~ 316.2
Thanks in advance.
