A
Al Sim
I may have missed the answer to this one in the wealth of information on this site, but is there a gizmo designed to act as a front end for a sound card? I've got a PC with what seems to my ignorant mind to be a pretty decent sound card. What I'm looking for is something that will act as a little mixer and send a signal into the sound card's line in. Ideally this gizmo would accept 1/4" guitar jacks, and a bonus would be XLR mic cables. I can always get an adapter for the XLR cables.
While were on this notion, are there any decent studio monitors specifically designed to plug into a sound card's 1/8" speaker jack?
And what about that joystick connector? Is there anything cheap and cool I can hook up to it?
Thanks for your patience with what may be pretty stupid questions.
Depending on model, it'll do all that and more. You may need phantom power in the future and most decent preamps do that to.
I hate to break it to you so crude but all built-in soundcards are cheap crap. Get a decent sound card that goes in a PCI slot and you'll get much better quality. $50 will go a long way if you only need two simultanious inputs/outputs, which is often enough if you plan on recording one or two tracks at a time or use an external mixer and just record the main mix. Search the forum for decent cheap cards. If you need more simultaneos inputs and/or outputs to be able to record many instruments on separate tracks at the same, you need a more professional card and then you're looking at a couple of hudered bucks and up. How many tracks do you need to record at the same time? Remeber, on a computer, the total number of tracks and the number of tracks you can record at once is not the same. I presume it's comparable to bouncing tracks, but without the bouncing
