maybe you don't understand how sound waves capture in real space to relative positioning angles of one and many capturing points in space simultaneously? Maybe you must have learn by classroom instead of artisan like me.
No, I understand it just fine. But again --
WHAT DOES IT HAVE TO DO WITH HAVING A MIXER over simply using a multi-channel interface?
since the OP was aiming for recording a consolidation of many mics to one channel or a couple of channels (which has been done commercially since the late fifties).I was referring to one of my techniques that I have taught others and they use it commercially. The channel layout you probably don't understand and that is ok. That is why we only give you two tracks and pay you to nick-pick. the point is to consolidate like voices so there is more control over the mix as a whole.
Don't be an ass, okay...? I had several hundred recordings under my belt before I got thrown into the mastering chair on just about any board you can think of. Including Studiomaster. They weren't that great -- And I certainly wouldn't want to put someone with limited technical knowledge into a 30-year old console that's going to need a bunch of maintenance when he just wants a simple
and freakishly cheap way of getting some tracks into a computer.
I'll let you wonder about that since they were in vogue when you were a child. Maybe you should research who used them and what studios used them.
I don't even know what you mean by that... Been there - done that. They were the Allen & Heath of the time. Inexpensive, reasonably decent for the money, but nothing spectacular by any stretch.
Yes, the OP needs an interface, line levels in only, because those mic preamps on the interfaces are poor quality. And its better to use something that was used in the field instead of Chinese copies of gear that hasn't. Might as well use the correct stuff from the start. then replace with nicer later and not play the converter upgrade game.
So the "correct" stuff would be a 30-year old, probably rusty, certainly out-of-prime, noisy by today's standards (even with most of the cheap stuff), definitely large (etc., etc., etc.) console *AND* a separate interface (and all the additional cabling necessary, etc.) instead of just throwing a few hundred bucks into a single rack space with 4 or 8 preamps and no additional trouble...?
Let's leave it at "he knows his options now" and go from there.
