AlecBeretz
So, most DAWs give you like a two measure lead in when you hit "record"
I record some vocals and stop halfway through a verse. I hit record to keep going, but I can't hear my previous vocal line during the lead in. Is there any way to switch that? Un-mute the track you're recording on?
Usually I just use two tracks and switch back and forth to avoid overlapping, then splice them together onto the same track later... this is a lot of work tho. If I'm working under time constraints this would be a wonderful tool.
Thanks HR.
Thanks HR.
