B
Bulls Hit
My current buffer settings are 2 buffers, 384 bytes each. I get really low latency which is great.
However when running some heavy plugins I start to get pops & clicks, but
when I try to adjust the number of buffers under Options, Audio, the field is locked on 2 buffers and the slider adjustment makes no difference. All I get is a button that says 'Asio Panel'. Pressing that takes me to the M-Audio Delta Control panel, where I can adjust the buffer size, but not the number of buffers. And before I can do that, I have to first of all go back to Cakewalk GT3 and shut it down before the new settings will take effect, which is pretty clunky.
So questions are
1. Should the number of buffers be locked on 2 like this, or have I set something wrong somewhere?
2. Is it better to adjust the buffer size rather than the number of buffers? What I'm trying to do is temporarily increase the number to accommodate these plugins
3. Should I be using ASIO or WDM on my Delta 44? Would the WDM drivers perform any better?
So questions are
