johnnypraze
Hip Hop Head
I understand that the low cut switch is but not so sure about the 10db pad.
When are these used and why?
The pad just cuts the source signal level down 10db so it doesn't overload. You'd engage the pad when your trying to record something that's really LOUD... too loud to work without the pad turned on. In other words... if it sounds distorted, overloaded, turn the pad on. But also remember not to use the pad unless you have too.johnnypraze said:I understand that the low cut switch is but not so sure about the 10db pad.
