C
cedartree
I'm playing an upright and recording in garageband using a Saffire Pro 24 and two mics -- an MXL 990 and a 991. The condenser is right above the strings of the piano and the cardioid is a few feet back from the piano to capture ambiance. I have the mixing knobs on the Saffire set at around 6 to 8 (I've been playing with these up and down) and on the software mixer provided by Saffire, I have it set to zero. Basically, I'm trying to set the levels so that it's as loud as possible without getting in the red. I then mix down to an mp3 in garageband (I used a fairly reasonable focusrite software compressor within garageband). Problem is that it sounds okay but sounds too "small" and soft. If I play another commercial mp3 song, it sounds a lot louder at the same volume setting. If I increase the mixing levels though I think I'll get too high and get into the red.
Suggestions on how to not see the mixing level too high and yet have the final recording be loud enough?
Thanks, from a newbie!
That seems a little melodramatic. I get your point, but I'm not so sure I totally agree with the way you stated it. Music can absolutely ebb & flow without spikes, and dynamics can indeed be maintained through compression. Keep in mind when I used the term "spike", I meant just that. I'm not talking about the "hills & valleys" of the wave form...
Well said!
