Thanx Queue. Calling me Mr. Analog and noting my advice is good is quite a compliment
...coming from you.
And Queue, your recordings sound pretty darn good too, for a Newbie, [haha]. Keep up the good work, I'm interested in hearing more of your stuff, someday.
BTW, Queue, Happy New Year, and long-time-no-see. I was starting to wonder what happened to you, lately, since you got off to a BIG start on HR, in 2001, burning up the boards, but I've not heard much from you for a couple weeks.
Anyway Queue, thx again. Cheers.
Charva, like Queue and others said previously, you're on the right track, but you'd probably be best starting & stopping the 'puter recording software between takes, so as not to max out, mess up, crash or otherwise lose your song data. Starting & stopping the recorder between takes just makes sense, and it definitely helps keep song file size down to a manageable level.
Anyway, even in the analog world, you'd typically stop or pause the recorder between takes, and hardly ever will analog-types just run tape, on & on, endlessly for hours... unless you just have money to burn.
-With cassettes, being so inexpensive, you'd realistically be able to run many hours of tape, on end, without undue financial hardship, but for bigger formats, using more expensive tape,... hardly ever will you do that.
I may be a hardcore, unwavering analog fanatic, but I have not lost my common sense. Analog or otherwise, I consider myself to have a fairly good depth of knowledge about home recording.
Thx again. Q, nice talking to you, and Charva- good luck, you should do fine.
/DA
