Cion said:
But you can count the BPM though, so THAT's why I don't get it. I count the BPM for the vocal, and the beginning usually starts out good, but then it floats off out of beat. I mean, I set the tempos to 93 90 89 etc.etc. it's rare I set the tempo to like 89.5 93.2 it's always a even number (not literally).
Who records to 95.something?... I mean, I've never did that unless I used a sample in the beat and had to match the beat to the sample. But I'm using a vocal to a track with no samples...I don't get it.
Here's the answer: Human Latency
Simply sequence up a click track (say 90 BPM), and then free record anything (Keyboard, guitar, whatever). Now go back and remove the sequenced click track, and try mapping out the tempo, for the part you recorded live. I can tell you this right now, unless your brain can be hooked up to your PC via highspeed FireWire, when you map out the tempo you'll find it doesn't remain at 90 BPM, it floats above and below (Sometimes as much as 10 BPM in either direction is not uncommon, especially with lower tempo'd songs). Work-around, set your click track to run at twice the tempo (which gives your brain more timing information to work with, you'll find most people when playing say a standard 4/4 track will tap there foot to the quarter note(1234,1234), while drummers usually count 8ths or 16ths (1&2&3&4&,1e&a2e&a3e&a4e&a), it helps them focus on the tempo I guess).
For your problem try this:
I just completed a project which was originally recorded as a solo guitar, which I got with no click track. I set up the first down beat right on the grid (Working in linear time base). The song was 174 measures long (at double time 160 BPM, he wrote it at about 80 BPM), and each chord change occured every other measure. So I set a tempo marker on the tempo track every other measure. So with the first beat lined up I drag the first tempo marker until the measure line above the next change lines up with the physical wav itself, then jump to the next tempo marker, and the next, and so on (Basically writing a tempo change every other measure). I could have gone every measure, but for the tempo I was working with, every other measure created a very natural bit of drift between real and sequenced in between the markers. It is a bit confusing the first couple of times you work like this, but it can give your performances more life if you actually record your own music like this, if you use sequenced drums, etc.
