legion got it right on when he said that a limiter is an extreme form of compression. Generally, you can think of a compressor with a ratio of 10:1 or more as limiting. Now the exact definition of when compressing becomes limiting is vague, and could be debated at length, and other factors (not just ratio) may play a role in the differences, but this is a very basic sense.
With really high ratios, anything above the threshold is reduced so much, it essentially hits a wall (hence, brick wall limiting) and is limited to the point of no signal above the threshold.
Crossovers can be complicated, as there are different kinds, and different kinds of filters that can be used, but essentially, if you have a speaker with a tweeter and a woofer, each driver handles its own information (high freq. for the tweeter, low freq. for the woofer). The crossover network is the thing that splits the audio and sends the highs to the tweeter and the lows to the woofer.
Basically if you take a high pass filter, and a low pass filter, and cross them, the point where they cross is called the crossover. A two way crossover will have 2 filters and 1 crossover point, splitting into high and low. A 3 way crossover has 3 filters and two crossover points, splitting into high, mid, and low. Crossover networks can also be active and passive. And the there are a few different types of filters (Bessel, Butterworth, Linkwitz-Riley). I think that wikipedia does a decent job of giving a basic overview of crossovers.
http://en.wikipedia.org/wiki/Audio_crossover
Also here's a basic signal flow of active versus passive crossovers:
Passive: Amp->Crossover->Tweeter
-------------------------->Woofer
Active: Crossover->Amp->Tweeter
------------------>Amp->Woofer
