Massive Master
www.massivemastering.com
I agree totally - But NOT "as hot as possible" -
Massive Master said:I agree totally - But NOT "as hot as possible" -
Yes, he is saying that is wrong. You need to get your signal up to line level as soon as possible. There is a big difference between line level and 'as hot as possible'.David M said:I interpreted "as hot as possible" to mean as hot as you can get it before it starts to clip. Are you saying that is wrong Massive.
Something to remember here is that at the beginning of the chain we're still talking analog. There is no clipping at zero in the digital sense. It is possible to drive many pieces of analog hardware well over zero, well over it's "sweet spot" and well "into the red" as measured on line-level-calibrated meters.David M said:I interpreted "as hot as possible" to mean as hot as you can get it before it starts to clip.
zenpeace69 said:Ok, so just now I was messing around with the levels between my mic preamp and my USB interface. Basically, as hot as I can get it without compromising sound is like this:
Mic Preamp Gain 11 oclock
Mic Preamp Output 11 oclock
USB mic input 1 oclock
USB mic output 1 oclock
If I raise any of these levels I start to get clipping and static. It actually sounds pretty good about there.
So just use your ears? Now that I have found these settings for my acoustic and this 8 Ball mic I want to write them down so I don't forget them and have to fiddle around wasting time next time I wanna record my acoustic.
Thanks for all the advice, everyone!
bennychico11 said:And for the last time, DON'T set the levels as hot as you can get them without clipping. There is no point in doing so.
(god, I wish digital companies would start putting 0dBFS lower on the scale so people would start freaking out if their signal went to high).
SouthSIDE Glen said:In the meantime, in general, you can get a great signal path keeping the level at line level (near 0VU on the metering) all the way through.
G.
As long as all the meters you are talking about are analog, yes. The digital meters are the ones that you don't want to be anywhere near zero.David M said:Okay, I think I have been doing it right then because this is what I do. What I meant by "cliping" was that the meter goes in the red. I often run my preamp into a Vocal producer or a reverb and I'll turn up the preamp until the input meter on the next device is at o. Then when I run into the firewire I do the same thing; I'll turn up the output on the last device so the firewire meter is at 0 and the red light is not clipping. I don't mean to beat a dead horse but does this sound like I am doing it right?
That is a hint and a half that everything is way too hot. Clipping on most gear is about 18db to 24db above line level.zenpeace69 said:If I raise any of these levels I start to get clipping and static.
I'm with Jay, it sounds like you are running a preamp into a preamp. No wonder your signal is too hot.zenpeace69 said:Mic Preamp Gain 11 oclock
SouthSIDE Glen said:I'm with Jay, it sounds like you are running a preamp into a preamp. No wonder your signal is too hot.
G.
Farview said:That is a hint and a half that everything is way too hot. Clipping on most gear is about 18db to 24db above line level.
The way you worded that, it sounds like you are running a mic preamp into another mic preamp. That would be bad as well.
Your mic preamp should be plugged into a line input. The line input should require no more gain because you have enough gain coming out of the mic preamp.
