Bristol Posse
Okey Dokey
it's a blackstar ht 60
What interface are you using?
I checked out the manual online and it didn't go into detail about the emulated out. It just says to leave the amp on standby. My Marshall JVM410 has an emulated out but I never use it. I'm going to try it today and see what it does with my interface. I find it odd that there's not some easier way to do what you're trying to do.
the interface is M Audio Fast track C600. just recently added the db12 di box.
thank you. i agree. my old marshall had a volume control for the line out. i guess the only volume control i have is the channel volume knob. i've been wondering if i would be able to use one of the other outputs instead of the emulated line out. i have 5 other out put for different ohms. the emulation is not that good, i still have to use Revalver or TH2 for adding a cabinet in the DAW.
No! Only use the emulated out. Do not use a speaker output. That could be real bad.
i definitely wouldn't without finding out if it was ok to do first. curious to hear about your experience after you try it out.
on a side note.
f this , it's time to buy an Air conditioner. LOL.
Are you plugging the Line Out of your amp into the Mic/Line inputs on the rear or to the instrument inputs on the front?
Are you using XLR or 1/4"?
I looked at a pic of it online. Looks pretty standard to me. So what happens if you go from the emulated output of the amp, direct to an input of the interface with the interface pre gain turned all the way down?
if i go straight from the amp to the interface with the gain all the way down i still have to turn the amp way down to not be too loud. that's even with the interface pad on.
so it is exactly the way mine works. so would you recommend the heavy padding in order to turn up the amp more to get the tubes kicking? i guess im thinking of it kind of like an attenuator. or should i just say screw it and make an isobox. lol.
Well an isobox would mean miking a speaker, and I'm always for that, so yeah do it if you want to.
Otherwise, I'd say do whatever you have to do to get the sound you want. If cranking the channel in emulation mode gets the power tubes involved somehow, and you like it, and attenuating the signal on the way in gives you satisfactory results, then do it.
I get it. I go through phases too. I mean my shit always sounds pretty much the same, but I tend to go in different directions within my tiny little narrow scope of musical interest.sounds good to me. i don't know how i ended up trying to micro manage every thing all the sudden. i used to be the type to just plug and jam, now i have a 10 band eq that i can't stop playing with. i listen to a lot of different music and i'm always flip floping on what i want to sound like now. lately i've been listening to a really neat band called Big Business, and another called Gojira. i think my fave after all this time is still Faith No More, i just love there range.
and thanks again dude. i've listened to some of your stuff dude, it's great, and if you can get a great sound without nickle and diming every aspect then it's an inspiration to me.
it's all about using the right sound and capturing it effectively. Get a good track of a good sound and the rest is very easy. I think people tend to overcomplicate things by worrying about every little piece of gear or plug-ins and spend too much time trying to fix things in the mix.
i was going into the front, but when the di box arrived i now go into the back with xlr cable. the di box allows me to further pad the signal.
