dobro
Which goes to show that you haven't been dealing with engineers like the ones sjoko described above.
If you are recording for a CD (not DVD), I recommend using a 44.1 sample rate. The conversion from 48 to 44.1 will probably sound worse than just recording to 44.1 in the first place. And if at all possible, record in 24 bit. Digital processing loves those extra digits!Espadrilles said:
I am recording in cubase in 16bits - 48 kHz via a Guillemot Isis soundcard
Chibi Nappa said:If you are recording for a CD (not DVD), I recommend using a 44.1 sample rate. The conversion from 48 to 44.1 will probably sound worse than just recording to 44.1 in the first place
sjoko2 said:
I'm sorry, but that is not a very good, or correct , recommendation![]()
mixmkr said:
adding to the questions of mastering....how often would a mastering engineer see a mix that hasn't had a final fade out (or in) applied to the mix yet?
While I hate to be a pedant... okay, no... I love to be a pedantAs opposed to recording at a higher rate and dithering down to 44.1.
sjoko2 said:Littledog .... If you read the post in question carefully, it was advocated to RECORD a project entirely at 44.1 if it ends up on a CD. As opposed to recording at a higher rate and dithering down to 44.1.
Obviously this is ill advised, as as the benefits of recording at higher rates are unquestionable.
mixmkr said:
nobody know this answer?....is this a common procedure to do the fades at mastering?
