AvoidTheClap
only the 2nd non acoustic song i've mixed. equing & drums are proving to be a pain in the butt...heh.
anyways, here it is:
advice/input appreciated.
JazzMang said:Give us some more info about your setup and we will be able to give you some usable suggestions.
JazzMang
i dont know what kind of gear you are using to record, so I can't give you any ironclad suggestions about your setup or anything, but all I know is that the drums (and possibly bass?.?)
JasonB93117 said:After a quick listen the song sounded like it was mono, did you make use of panning on any of the instruments?
guitar cab micing is small diaphram right dead center in the cone, & large slightly further away & offset.
Wireneck said:Ill try to say this as nice as I can. Here are the Big problems of many....
-Kick is like in a space completely of its own.
-The guitars are thin and close to being one of the quietest things in the mix
-Vocals are out of key quite a bit in many places. Pretty annoying
The balance is just way off on everything. It sounds like you have a guitar/bass mix playing with a kick track solo'd on top of it and someone singing over that. I don't know any other way to put it.
This is just how I hear it on my monitors. I definitely think a remix and maybe some re-tracking is warranted. You should be able to get better results judging from your equipment list.
