M multitrak_ent New member Nov 19, 2004 #1 i was just wondering would i get latency from using the alesis ai3 with hardware efx with a 002r when mixing down?
M MOFO Pro Opinions are like SM-57s Nov 19, 2004 #2 I'd highly doubt it... latency issues are typically from inside the box... cpu load... processing performance, etc. Hardware processors have virtually no latency, therefore no delay in your signal chain.
RawDepth Well-known member Nov 19, 2004 #3 Since the AI3 is primarily an input device, I doubt you will even be using it during mixdown, unless you are sending the output back through it again.
M MOFO Pro Opinions are like SM-57s Nov 19, 2004 #4 He'll be using the convertors for an effects loop to a hardware device outside of his DAW...
