A
apodos
Just recorded a song in sonar 8.5 producer and used many soft synths with midi controller and things went great.
Now recording second song and I suspect I changed some audio settings and created the following problem and can't figure what I did:
When I open any synth(true piano, session drummer, or any other...) and play, sound works fine. No latency. Then, when I press play on the project I'm working on, the problem arises. After having pressed play, the soft synth plays AND records with about a 1/2 second latency. Then, when I turn audio engine off and then on again, the latency is gone.
If I record midi data into a track it records with latency and then I drag/drop it back so it fits the timing of my song...
I have an echo audiofire 2 interface and windows 7.
Everything else seems to work fine.
