C
clntgn
So, I've been having what I've heard is a common problem: latency. I've tried a lot of stuff, but none of it seems to work.
The software I'm using is tracktion. It came with my usb microphone I just got for christmas.
I'm recording into my computer through a Boss GS-10 guitar effects system.
Here's my issue though: I record one track, no problems. Then I record another one. Everything is off sync, even though I played it perfectly while recording. I know this is a delay between my computer and what I'm hearing, but then there's more issues. I screw around with the recording quality, set it up to 48000hz instead of the default 41000 or whatever. Then I mess with the latency, and I finally get it somewhat close enough that I can record it without it sounding too off. Then I record another track. lets say a bass track and the others were drums (1) and guitar (2nd). The bass track comes out sounding fine the first time I record it, but I make a couple mistakes, so I decide to rerecord it. I delete the tracks, and record it a second time. Now its out of sync, and no matter what I mess with I can't seem to get it in sync.
This as you can imagine is very frustrating as I just want to record a few simple tracks, but can't even do that without numerous stops. I don't know what to do. I've tried auto detecting the lag, but it says I need to set up my audio equipment to loop, and I don't think I can do that.
Make sure to close out and reopen your software every time you make a change with ASIO.
