P
PhilandSue
I just bought a KX88 because the action was so awesome, brought it home and find that I can't get the sustain pedal to work. I have the midi OUT going into a Casio CTK-571 midi IN. I am using a VFP1 footpedal which has the switch underneath to select normally-open or normally-closed. I have downloaded the KX88 manual and it says after reset that FS1 should be a sustain switch. I have tried many combinations of NO/NC footpedal switch, power-cycling the KX88 with footpedal attached or not, etc. No sustain! But when I plug into FC2 with the power on, the KX88 is in Sustain all the time, regardless of footpedal position. Under some situations, I get no sound unless I plug only part way into FC2, making me think the jacks are just all corroded or damaged. Is this a settings problem, or do I need to get a screwdriver???
Please help, otherwise the wonderful action may have to get returned to the store and I'm back to my springy little Casio keyboard again.
