rayc
retroreprobate
I took the opportunity to test my xmas gift. I'll have to put it back in the box but needed to ensure it wasn't DOA (as if anyone is likely to believe it but it is, at least, a pragmatic confection).
I used my usual rig:
Bruno Royal Artist semi-acoustic single coil - bridge pickup
Kustom Head
Marshall VS 412 lead cab (not too flash)
57 mic on the edge of the bottom left speaker into Focusrite 8i6o Scarlett & recorded in Reaper.
No pedal, nofx no compression of treatment.
Starts out with the same chord progression I've played on the last few. Amp vol dial (the ONLY dial) set at just above the 1st mark (about 9.30).
I then play a newer progression in 5ths/powerchords increasing the vol each time through. The last time is with the amp at max.
It's all very loud in the room and I needed ear protection for the increasing vol takes.
The tone of the speaker/mic combo is a little dark but that's fine & is consistent with previous tests.
Please excuse my playing - arthritis is an issue today.
I did play around with pedals in front of the amp but at this stage the amp/speaker/mic combo is the most important.
Observations?
