I thought I'd share again the comments I posted from David Josephson just over a year ago on the issue of quality control in mike manufacture. The applicability to other products may be less apt, but I think it's still of interest since so many folks here buy microphones. I asked him about the differences in design and production of his high end mikes compared to the low cost mikes, mostly from China. Life is generally not as simple as a one liner and David gives an interesting and elaborate reply. I find his comments on tolerances, rejection rate and reliability very relevant. The Chinese mike production strategy is what it is and produces what it produces.
Cheers,
Otto
"Otto,
There's obviously only so much time for answering such a question ... but I'll try. I know a bit about Chinese production strategy, having worked in that country about half time for five years in the 1980's (not in audio, but in geophysical and lab instrumentation). I have a lot of respect for their industry and resourcefulness, having seen the results of their pulling themselves out of a Soviet-generated technological dark ages in the 1960's (read up on the history of the famine and the USSR's technical pullout from China during 1959-1961). They kept the brute force engineering they learned from Soviet universities in the 50's which was focused on producing adequate and robust technology cheaply in huge quantity. If you make a thousand toasters, no one minds if 5% of them are faulty when there's an extra 10% included for free with the thousand you made. This is a valid and powerful cost reduction strategy -- but not for us. Today of course Chinese industry is moving beyond that in semiconductors and other major technologies, but studio microphone capsule production is still a small business for everyone. There are something like 20 billion electret condenser microphone capsules made every year -- a few tens of thousands of studio condenser mic capsules are in the noise and the few hundred we make aren't even on the chart. No one discussing these issues has a clue unless they have been through the process themselves, and those who have, typically find no reason to participate in the discussions.
All of the aspects you mention are relevant, and there are many others. A capsule is designed based on the knowledge that certain tolerances can be achieved in production. The first difference is that when you know tolerances are loose, you can't specify dimensions in the design that must be held to close tolerances. Some dimensions in the Series Seven capsule must be held within a ten-thousandth of an inch; if you can only get to a thousandth, you can't make that part, so you're constrained to designs that don't require such tolerances. The capsule in most Chinese big-diaphragm mics is a derivative of the Neumann KK67 capsule, which is an improvement of the Norddeutscher Rundfunks M7 capsule designed by Braunmuehl and Weber in the 1930's. Ones that won't work in a multi-pattern mic because the halves don't match will work OK in cardioid only (as they were originally conceived); one side or the other will work OK. The AKG CK12 capsule of the 1950's was far more demanding in terms of machining precision; even AKG had a hard time getting them right (different examples are all over the map in terms of response, for reasons we understand) and they ultimately decided they were too difficult to make. The guy responsible for that manufacture, as far as I know, was Bernhard Weingartner who left AKG and went on to found Neutrik. That design is the basis of the Series Seven capsule, and we have been producing our version with continual improvement since 1989 ... we have learned a lot. AKG would probably have done the same if they had decided to stick with that design. There are several books of notes on this topic here chronicling successes and failures, true discoveries and barking up wrong trees, which as you can imagine I'm not about to share. The three principals of the company have unique skills in manufacturing, electrical engineering and physical acoustics, and without this combination of skills I don't think we would have been able to get to where we are today -- which is that one of our techs can set out the parts to make 20 capsules and come up in a few weeks with exactly 20 capsules which are all the same (unless we want them to be different, which we sometimes do for our OEM customers). There is no single key to this performance -- it is the sum of a thousand little pieces.
And then there is the issue of reliability. Nearly all of the original large diaphragm capsules that I made in the early 1990's are still in use and performing exactly as they did originally (although it took me much longer to get them there than it does today). There were failures and degradation issues for the first couple years of production but all of those capsules (which reached the market in very early Manley Gold Reference microphones) have been replaced, and those issues are now fixed. Since my last industry work before starting my company was in a military quality control system that I developed and managed, I was preoccupied with this from the beginning. You can look at many of the low cost microphones on the market today and see where economies result in tolerances that degrade with age, and this degradation is seldom good. This is the ultimate limit to the low cost, weed-out-the-duds approach. A capsule that sounds OK today may not tomorrow; there's no way to predict how things will warp and stretch if the materials are not stable. We simply don't have capsule failures in production mics anymore, these are fairly easy to prevent if you know what's going on for any manufacturer that's willing to take the time and expense to engineer the process properly. Even that doesn't prevent big name companies from rushing capsules into production when their long term reliability isn't known -- there has been at least one example of this in recent years where a whole production run had to be recalled.
Feel free to quote and distribute this reply as you like.
Cheers
David Josephson"
