mark4man
MoonMix Studios
Crew...
Have been attempting to master my CD with a pair of KRK Rockit 8's; & have been pulling the ol' hair out with my vocals. The vox are too dull; & every attempt at high-end EQ creates a buzz...regardless of quality of plug-in or curve utilized. Any kind of stiff attack or burst in the lyric content; & its buzz city. Any kind of (even close to) overmodulation or harmonic distortion; & I get that scratchy, scrapey flavor.
[I've also posted in these boards in other categories looking elsewhere for a solution; & have been helped by members quite a bit, but to no avail.]
Then, the other day...I ripped a few songs from favorite CD's past & listened to those thru the KRK's. I can hear every damn buzzy burst & harmonic distortion scrape in every vocal line !!!
So...my question is...are these things too accurate...or do they not handle certain signal characteristics well...as a manufacturer?
I believe in the theory of nearfields (what you hear is what you get); & that when, your mix sounds good on them...it will sound real good on everything else...
...but, come on...
...I can't make anything sound good on these things. They say nearfields have to be “learned”, but I can't judge correctly with these monitors; & I don't have time to burn CD's & then run around & audition tunes on every kind of system...come back...tweak, etc., etc., etc.
Does anybody else out there own this model? Could use some input.
Thanks,
mark4man
Dell Dimension 8250 / Windows XP
Intel 850E Motherboard/Chipset
Intel P4 2.53GHz CPU (512 KB L2 Cache, 533 MHz FSB)
1024 MB PC1066 RDRAM
Ultra 60GB Primary HD / Single Volume (OS, Apps, Files/Folders.)
Maxtor DiamondMax 9+ 80GB Secondary HD / Single Volume (Audio Data only)
nVidia 64MB GEFORCE4 MX420 AGP
Echo Audio Layla 24/96 PCI Audio Interface
Universal Audio UAD-1 DSP Powered Plug-In System
KRK Rockit RP-8 Studio Reference Monitors
SONAR XL 2.2
SONAR4
WaveLab 5
...but, come on...
Thanks,
mark4man
SONAR XL 2.2
SONAR4
WaveLab 5
