In order to clear drive space on the d-8's internal drive korg says to turn the unit off then on again.What about clearing over written material on an external drive(syjet 1.5gb)same thing?Also why can't I back up files to a sony disc machine?It uses the same digital/optical connections as a DAT machine.Mini discs are much cheaper than drive cartridges.By the way the d-8 is a pretty good unit if you don't mind only two inputs.
