For any modern jazz or fusion listeners out there, often on live gigs the kick drum has this HUGE fat, punchy sound, that i don't hear very often on records. Is there a reason that it is not generally recorded? And how do I get this sound! For some kind of idea what i'm talking about see
https://www.youtube.com/watch?v=x0P7Pi47Va0
It's not that audible, but if you've heard it before at a live gig you'll know what i'm talking about...
Hey Moley,
Well first things first, when it comes to live mixing and studio mixing, the process becomes two completely different things.Alot of the physics are the same, but two entirely approaches because of the limitations of a) the media and b) the end user.
(Research "speaker voicing")
Now some philosophy:
A live mix is born out of live situations, while a record mix is born out of preserving an artistic ideal.
In live sound, you're mixing to reinforce. On record, you're mixing to recreate something that's going to be heard as a feature presentation on x number of systems. It's an audiophiles nightmare.
What alot of people don't realize is that a good recording is not overblown at all. It has nothing to do with volume, but rather tone shaping and dynamic processing for effect and control. Good mixes are actually pretty flat. And there's a reason for that:
Flat, untethered mixes tend to translate best over a wide variety of systems.
This especially goes for the kick, being the anchor for most types of mainstream music. You name it, reggae, rock, hiphop, country...
A kick on record has a traditionally different timbre. It's a matter of getting used to the difference. Learning the difference. Accepting that there is going to be a major difference.
Think about it:
In live, you have different variables. The sound system is alot louder, probably produces a better lows and highs, is *unmastered* so you hear everything raw and more to the actual source.
Record mixes are at the mercy of mastering. Everybody wants loud, so they get loud. But transients suffer big time.
You really do get a limited amount of sonic real estate to mix with anyway. You figure that you only have a 20hz to 20khz range to work with, with an ultimate dynamic range of 90-144db (depending on your final medium), a kick's fundamental alone takes up the entire lower portion of the spectrum.
So things get eaten up real quick.
So your question was "why does the kick suck on record?"
Because overtime, tons of smart engineers figured this was the best way to do it.
It took me (and is still taking me) a long time to get over the romance of what I used to think a sound on record was like and learning what it *actually* sounds like.
