A
ambi
So what would be the best coloured dot to look out for?
mgraffeo said:BTW, the colored dot on the box of SP mics will match mics pretty closely. It has to do with what the tolerance is on the frequency response curve. If a given mic is slightly higher, it gets one color. If it's slightly lower, it gets a different one. And if it's pretty much on the line, it gets the third color.
Just wanted to clarify that it doesn't really refer to the sensitivity of the mic.
-mg
ambi said:So what would be the best coloured dot to look out for?
DJL said:-35dB +/-1dB, is marked by a green dot on the packaging
-36~-37dB, is marked by a black dot on the packaging
-33~-34dB, is marked by a red dot on the packaging
crazydoc said:If this is so, then another way of writing it would be
-35+/- 1.0 = green
-33.5+/- 0.5 = red
-36.5+/- 0.5 =black
so it looks like the red or black are more closely matched (very closely matched) than the green? These tolerances don't really seem realistic for the price.
BTW, regarding the 67 vs B1 question, I have both, and I like the 67 much better for my voice. However, I have a very bland, boring and neutral timbre to my voice, and the 67 gives it at least a little pleasing color. The B1 seems a much more neutral mic, and does a good job of making my voice even more unexciting.
crazydoc said:DJL
I don't mean to question your veracity or what he told you - I'm just wondering if the specs can possibly be this tight, and if the red and black dots are tighter spec'd than the green (cause mine is green)
alanhyatt said:Sorry guys... I am in Germany at the Frankfurt show....
The correct sensitivity should read...
-33~-34dB +/-.5dB, is marked by a red dot on the packaging
-35~-36dB +/-.5dB, is marked by a green dot on the packaging
-36~-37dB +/-.5dB, is marked by a black dot on the packaging
I do not have more time right now, but myself or Brent will get back later...Sorry for any typo error's, but the spec is tight when you get the same colored dot as a pair.![]()
mgraffeo said:I stand corrected. my bad for disseminating incorrect info. Thanks crazydoc, DJL, and Alan for setting me straight!
-mg
