just got into serious recording and need help to get rid of "booming" vocals
  • Thread starter Thread starter breakin' atoms
B
breakin' atoms
i've been recording for about two years just doing things with acidpro, my turntables, and sampler, and i want to know what type of equipment i could use to get rid of (1) overly bassy/booming vocals (2) the annoying low frequency hum from my sampler. I've been told a compressor would help me, but i'm not sure what i would need....
You need EQ, not a compressor. If you have proximity effect on your vocal mic, roll off low frequency stuff below 75hz or so. If you have a low freq hum from a piece of equipment, it's very possible you have a ground loop. You want to address the cause on that and not the symptom.
What type of mic are you using? How are you getting it into your computer, etc?
A low cut filter at about 100 to 200hz or a better mic, not a compressor.
In a pinch try just getting a little further from the mic and turn the preamp gain up a bit to compensate.
Doing this, recently, helped me with the same problem: I hung a duvet over the door, then stood between it and the mic to do vocals - took out a lot of unwanted bass and boxiness. I got the idea from Sound on Sound.
<smirk> He said "duvet"!
Breakin Atoms: Most of your post throws red flags up to low pass issues. Take a peek at your sound settings first off and see if you can adjust the low frequency there. I wonder if you are using a mixer, an old stereo receiver/amp, or what other means to get your signal into the PC. Shitty connections on old cables can be thwarting you as well. Un-shielded cables could be an issue here too.
What's a duvet? Are they expensive?
Is one enough? Is two too many?:rolleyes:
I used to call it a quilt, then I was told that was wrong.
