Hi all,
    The  bad:
    #1 I tried to put Jim Dunlop strap locks on my Variax and found that the strap button on the butt of the guitar is VERY thin where the routing for the electronics takes place. I drilled the screw in, noticed it went as far as it could go and was still loose. Out of curiosity, I opened the plate up on the back and saw to my utter horror that the screw was protruding into the body where a circuit board was sitting! Even if you could get a shorter screw in, there isn't much wood there to support it.I put the original strap holders back on and called it a day.
   #2 I paid close to $1000 for mine and it didn't come with a hardshell case.One would think that with electronics and all, it would have been standard.
     I'm running mine usually through a Fender Cyber Twin and find that on some presets, the high E sounds louder than the other strings...there is a website with a forum that explains how to tweak the volume of each string individually without hooking it up to a computer. It's all in the knobs.  I also wish they had a droning sitar, but you could probably do this with a delay.
    When people say that the models sound the same to them...I'm betting it's because of the overdrive/distortion on the amp. Hell, if you distort the crap out of any guitar, it's going to sound like a distorted guitar...period. I actually did this myself the day I bought it...I went to an over driven sound on an amp and switched models with little difference. The sales man cleaned the amp up and said "now try it"...sure enough, BIG difference. If they can't distinguish the tones on the Variax with a clean setting, they probably are somewhat tone deaf. I can't help but wonder how many guitarists crank up and over driven amp to chech out a Variax and walk away feeling it's not all it's cracked up to be. I think it really shines on somewhat cleaner sounds.
J.P.
