Thanks a lot cyan, there's a lot of really helpful advice there. I replaced the old mix with the new one, hence there's only one journey... i hope it has been replaced anyway, but from what you've said I think it must have been.
The drums were created in some drum editor that I have in cubase VST, and I've never thought they sounded too good on any of my previous songs, so I did a bit of playing around. I basically increased the eq at 80hz a wee bit for the kick (which I have done before anyway, the plugin I'm using doesn't go as low as 40-60hx, I'll have a look what i can do) and I think it stands out to you because I added a bit of echo reverb which probably gives it the depth and warmth, I'll be using it from now on!
As for the snare, I think I'll need to have another look at it because you're right, it doesn't sound all that good, I think I added hall reverb or something similar and stuck with a poor compromise. Do you have any ideas as to what could improve it... I could just take off the reverb altogether and do something else, I'm not sure.
I'll bring the vocals up, the were much quieter than that before, so maybe I've just under compensated a bit. I take it you mean lead as in lead vocals? I'll have a wee play around...
I will follow your advice and pan the backing vocals more, I think I was just being a wee bit conservative when doing the first mix and I didn't really do anything about it the second time around.
Haha, it's probably just as well you can't comment on the bass, because it wasn't a bass, i used the same guitar as for the other guitar parts, just increasing the low frequencies to try and make it sound authentic... I really do need to invest in a bass one of these days!
Thanks again and I'm pleased you enjoyed it
Jags
