MCI2424 said:
Side-by-side,the new ones are different and most components are the cheaper variety of parts. Mine is a good old Fletcher designed and cost some $$ to build. Sounds great. The new ones are probably fine too. I just like the opto-comp on the old ones better.............as stated somehere above by someone else.
If I told you how much Ted Fletcher's old gear cost to make, you would crap your pants. Even I was surprised to learn how cheap it was after I bought the company and learned all the details. If anything, all of us were fooled. So your statement of how much it cost to build is based on a guess, and that guess is wrong...
As for the optical compressor, the new Meek is 10 times faster than the old Meek. Many users try to use the new Meek the same way as the old...With a much faster attack time, you can't do that. The difference would be profound and the compressor would be extremely percussive on the new one making it not sound good on vocals. You have to slow down the attack time on the new ones to get them to sound like the old ones...but then speed it up for extreme compression effects on drums and mixes and its wonderful. The big issue is to learn to drive the new ones and think they work the same way as the old ones do.
If you open the new ones and the old ones and look inside, you can clearly see the extensive amount of added parts, better quality of pc boards and that the parts in the new ones are many levels above in quality then the old ones. The old AC transformers were very inexpensive plate types and had a high degree of failure. The new ones are all custom wound torroidal types.
As for the mic transformer, the Joemeek CS series did not use them. The very old ones used an RS off the shelf version. Now I am not saying the old units did not sound good, but the new ones are clearly better designed and use better components by design and have better tolerances.
In addition, the new ones are all CE approved and certified as electrically safe and tested by CE and issued a certificate. All older Joemeek units, and as far as I know all of Ted's new stuff is self certified...which is not allowed by CE without their testing. All manufacturers must carry a certificate by the issuing test house. That being CE, UL or other certified agency, which costs a lot of money to get done for your protection.
There is a clear difference between the old Meek and the new Meek. The old Meek has less control with no make up gain on the compressor, and it limited to one basic sound. The new Meek has extensive EQ and more control features, as well as digital outputs as standard for more flexibility.
In the end, you either like the new, or the old, that is just opinion which is more valid than a guess. I sold both of them for the last 12 years as I was the original US distributor from day one. I can tell you we sell more of the new ones than we did of the old, so that must tell you something.
What you have to do is understand the new ones. They were redesigned for a reason, and that is to be better. There will always be those guys that like the old 1967 Corvettes, and those that appreciate the performace of the new ones. Same holds true here, but it is clear which one is better designed and has better performance.
If any of you have specific questions about the Meek history and which rev is what, I am happy to answer your questions.
