muttley600
Banned
Yes, otherwise an electric-acoustic guitar would sound like a hollow body when it was played through an amp.
I'll ask nicely.Please stop, you don't know what you are talking about.
Most appreciated Muttley.
K.
there's a reason why les pauls are made of mahogany and teles/strats are usually made of alder or ash. it matters even on solid bodies.
...now, in an acoustic guitar we hear both the strings AND the top vibrations (no?).
Actually, all we are hearing is the top/body of the guitar when we listen to an acoustic guitar acoustically. The strings alone are nearly inaudible.
right, strings alone would be about as loud as an unplugged electric solidbody, right?
Would it be safe to say, then, that the top and acoustic chamber of a semihollow or hollowbody influences the amped-up tone of a guitar in a manner similar to feedback? Not squealing "bombs over Hanoi" feedback a la Jimi, exactly, but as the string is plucked, the top picks up some of that vibrational energy, it's amplified in the soundhole, and as the soundhole and top radiate sonic energy, some of that is in turn picked up by the (still vibrating) string, which induces sympathetic vibration and changes the way the string vibrates? I mean, this is obviously not the full picture and there's gotta be a ton of other factors in play here (off the top of my head,
Thats exactly it except to a acoustician damping is a seperate property but thats for another day.I suspect the body of the guitar has a slight dampening effect on certain frequencies on the string, which is also responsible for timbral changes), but at a "hollowbody guitars for dummies who play mostly rock" level, lol.
Thanks for the info, either way!![]()
Your correct, the wood matters to any guitar. Whether you like the sound is a subjective issue, but it definitely matters.what i meant in the quote below was ONLY that wood matters EVEN in solid guitars - those particular woods being "associated" with those particular types of guitar (as "the sound" of those guitars). That's why when there's a mahogany strat - it turns heads - it's not as typical and draws interest.
The reason I asked for clarification from you was because I wasn't sure thats all.what i'm wondering: since rockabilly-type and often jazz-type archtops are usually played electric and not acoustically, how MUCH of a difference does the top really make to the audience?
now, in an acoustic guitar we hear both the strings AND the top vibrations (no?). In an electrified guitar at ensemble levels we mostly hear strings amplified by pickups (albeit affected by the guitar material/construction in their respective ways). I just wonder, when one is playing with bass, drums and other instruments - how much of those finer components are lost, to the audience and to the guitarist?
Is this a good question?![]()
I think this is a good and valid question.
Muttley provided a fine answer to my original question; one that I greatly appreciate. It convincingly addresses the issue in "hard data" terms of how the type of wood used for the soundboard in hollow bodied guitars can affect the tonal qualities produced by a pup in an amplified situation.
Your question, as to whether or not the subtle variations in tone thereby produced will be appreciated by an audience in a drums, bass trio situation is another aspect to the question. I personally think not.
My experience of playing live (as opposed to recording) with a band is that the g. only occupies a relatively narrow range of the sonic spectrum that is the guitar's alone. Being a mid-range instrument there are too many other "noises" competing for the same aural space as it were. All those subtleties of tone which may shine through (with intelligent and sensitive tweaking of amp knobs) in a solo situation, are lost in the cacophony of crashing symbols, kick drum, snare and agressive (electric) bass playing.
On the other hand, from the guitarist's point of view, playing a quality arch-top (or any other type of g.) is kind of an end in itself. Any old car or motorcycle will get us from point 'A' to 'B', but do it on in a Bently or on a vintage Triumph - well, that's half the buzz... ain't it? And like it or not, just like good cars and bikes, good guitars are status symbols. The difference is, most anybody can ride a motorcycle or drive a car. But there isn't anything more embarrassing or humiliating to a muscian than someone in possession of a fine guitar who can't play the damn thing (but think they can)!
K.
If somebody already said this, I apologize for missing it:
"Jazz boxes" always seem to be, not just hollowbodies, but also arch tops. (Macaffini-types, and Gypsy jazz being exceptions) Now, this may just be because almost no one makes an electric flat top, but I suspect that it is because arch tops are NOT sustain machines. The design was developed before electric amplification, to channel as much of the sound box's energy into projection, to be heard over larger and larger jazz combos. If jazz developed with that "barking" guitar quality as part of it's sound, it follows that when jazz guitars became electrified, they would still be more projection, less sustain. Thus:
It is NOT "all down to pups and amps." Even if it were to come to that, the jazz tradition would still hold sway- and "pups and amps" made to play jazz would emphasize projection, not sustain.
I think (not sure, tho- so don't flame me) that the majority of arch tops, regardless of quality, are laminated tops. Perhaps this is done because sustain is not highly valued in jazz, and thus makers have (correctly, I think) deduced that there is no good reason to go to the expense of a solid top? If I am correct about this, then the relatively rare solid top may be more marketing and/or snob appeal than actually needed.
Certainly the construction of a hollowbody jazz box- it's hollowness, it's archtop, etc. have a desirable effect in the jazz guitar sound, so I would say that much of the guitar's wood construction- box design, wood, etc. DO play a huge role in the guitar's tone. Perhaps much more than solid body/rock and roll playing- jazz players insist on clean tones, rather than using (as a crutch?) distortion.
Just my two cents.
