Thanks for the responses!
For the record here is the rundown:
All instruments were recorded with a Boss BR-8
Clean Guitars were a preset patch in the Boss
Distorted guitar is a V-Amp into the BR-8 in stereo.
Bass is my el cheapo
Peavey Milestone III ($189.00 w/bag)
straight into the BR-8 using a preset.
Keys are
a Roland RS-9
Drums are
a Zoom RT-123
All tracks were loaded into Acid Pro 4.0 for mixing.
I didn't have to do much since I did a good job recording.
I sent this to Jamal with a take of me singing the tune as best I could. Fortunately Jamal used his right of artistic freedom and recorded what you hear. He claims it took him around 20 minutes and I hate his guts!!!
kidding!!!
His vox were on 4 tracks, but he did some punchin in on each one so I cut the 4 tracks up into 11 to get what you hear.
I compressed them a tad and put a little verb on 'em and then rendered these 11 down to 1 track. I reloaded that 1 back into the tune and put the waves metaflanger on it and its around 4 db under the original vox. The layered effect sounded cool so I left it (And since I don't know any better it was easy!)
Waves L1 at the end
Hope that helps anyone wondering how it was done.
chrisharris - Your ears are probably right in terms of placement of the voice. I was trying to be sure they weren't buried, and that they weren't competing with the instruments. It can probably be leveled out at a slightly lower volume and I can fix the plosive (which I obvoiusly didn't hear)
I appreciate the kind words!
B.SABBATH - the high voices probably can be blended better and maybe that will help. I will give this another shot after reviewing comments from legends such as yourself
As for why it sounds better than the one we are working on........
Thats an excellent question to which I don't really have a credible answer! My first thoughts are this tune has such a simple arrangement, and I got really lucky when I recorded it! Also, the tune we are workin on is in a vein I have never tried to record yet. The latest version will be heading your way tomorrow (I hope!
) and you should see a big difference.
As always your input is vital and Thanks for listening!
Guernica - Thanks for the kind words G! The only time I ever posted a tune here you were the guy who pointed out my bass flubs when I couldn't even hear 'em!
I took some extra time to get this smooth, and it turned out to be the anchor of the song. I even snuck in a chop or 2 but I will
never posess a portion of your Bass prowess!!
I'll continue to improve on faking it!
3M - Thanks for listening! I think I know which vocal parts you are refering to and I could do a better job of smoothing them out. I hope Jamal chimes in and shares his 20 minute technique
I will definately experiment with the reverb more on the next mix.
And I will get the BG vox more consistent. After a closer listen I hear what you mean. (softer in the first minute than the rest of the tune) Thanks for your comments!
wfaraoni - Thanks for the listen and I hope to addressyour point in the next mix. I appreciate you taking the time to listen.
I will give it another session and repost asap.
Thanks again!
Joel
