osus
okay, i've spent an hour or so reading posts and instruction manuals, and i think i have a basic grasp of how patch bays should work. i have a neutrik 48 plug patch bay that i'm trying to use to route the outputs from my mixer into the inputs on my delta 1010.
here are my issues:
1) i can't get it to work at all. i've set it up 'normal', with the eight outputs of my mixer and the eight inputs of the delta 1010 into the patch bay, with channel '1' of the mixer above input '1' of the delta 1010, and so on. nothing happens when i have it set up like this. i've tried swapping the position from top to bottom on each channel, and got the same result. i've been using xlr to trs cables from the mixer into the patch bay, and regular 1/4 to 1/4 from the patch bay into the delta 1010. is this the problem? will mixing ts and trs cables in the same mess things up?
2) i have additional sources beyond the mixer that i'd like to be able to switch out with the mixer outputs (and plug into the delta 1010) without having to crawl around the back of the rack. it seems to me like a patch bay should be able to accomodate this (i plug all my sources into the back of the patch bay, plug my eight recoring channels into the back of the patch bay, and then use patch cables on the front to switch things out as needed.) will this work, and if so, how?
thanks!
here are my issues:
thanks!
