miroslav
Cosmic Cowboy
While it's true that you are adding a cable connection...it's usually a balanced line level connection, so unless there are issues with the gear, there will be no signal loss or noise added....especially at that short distance...
...but I agree with Armistice that at the low-budget level, everything is about "all-in-one".
IMO...what suffers most from all-in-one budget boxes isn't the conversion...but the preamp. Often they are budget (aka lower quality pres)...also, not sure of all the technical specifics, but I would think there is more work required to shield the pres inside from the converter electronics. There's a reason why pres are often kept away from other electronic gear, as they easily pick up all kinds of noise/interference.
