dmbpettit said:
http://www.musiciansfriend.com/srs7/g=rec/search/detail/base_pid/333006/
Is this the right cable to sync a Delta 66 to an audiophile 2496? It looks like it is one single cable, not the standard rca Pair. Does this run from the spidf out of one card and into the in on the second card?
You are correct.. Here is more detailed info...
Syncing two Delta Series cards together
Configuring two or more Delta cards together can be done by linking the cards together through the use of external hardware lock via a 75-Ohm RCA SPDIF cable to allow synchronization between the cards.
The Basics:
When linking Delta cards, one card sends the master clock signal. The rest of the cards that are synced must receive signal from the card sending the signal. The S/PDIF connections on the sound cards are color coded for in and out. On the Delta series sound cards, the out is white and the in is red. SPDIF cables can be obtained from any Music Industry store or Home Stereo store.
Note about SPDIF cables, these cables are not the same type of cabling used for analog audio, the internal resistance of the cable is different than for analog audio. Although analog RCA may appear to work, it is not reliable. Examples of SPDIF cables can be found at
www.hosatech.com
1. Connect the 75-Ohm cable from the out (white) S/PDIF connection of card sending master clock to the in (red) connection of the receiving card. Each additional card must be hooked in a daisy chain type of configuration.
2. Open the M Audio Delta H/W. The installed sound cards will appear down the right hand side of the panel. Select the card sending master clock.
3. On the Hardware settings tab of the master card select “Internal Xtal” for the “Master Clock setting”. In the “MultiTrack Driver Devices”, please select “multiple card sync”.
4. On the Hardware settings tab of all other synced cards, select “S/PDIF in” for the “Master Clock setting”. In the “MultiTrack Driver Devices”, please select “multiple card sync”.
After these steps are taken, the hardware is configured for use. The only step left to be is setting up your application to use the additional card(s).
Hope that helps
