Sounds like latency. I'm not familiar with Reason, but is there a way to lower the latency setting? If so, you might try that.xiaoken said:It seem to work properly in Reason. However, it lags badly. I press a key and the sound comes like almost half a second later.
Also, when I try to run it with cubase, it says midi port is in use.
