M
MCI2424
jmarques said:I'm starting to think mixing and mastering is a farse. I don't think you can just mix anything you want together and no amount of mixing is going to fix a problem with sounds that don't work together.
I work on a lot of stuff since I've got into doing computer all the way back to 1992. Since then I've tried experimenting with a million different things and all them were pretty much a failure.
I've pick up serveral books on mixing, mastering, arrangement and production, acoustic space design and serveral web tutorials all related to audio within the last few years and have applied some of it to some success.
I've notice a common theme to successful mixing and mastering is knowing exactly what you want your sound to sound like. No second guessing!!
Processors and Effects are there to enchance sound to make it better. The keyword here is enchance if you have a mess of stuff that doesn't work pre-mix then there is nothing you can to with effects and processors to make it better. The Lesson Learn here is that if you have a poor arrangement with sounds that don't gel together and no amount of futile placement of effects and processors is going to fix problems in the mix.
I'm starting to become a firm believe that a good mix starts with goods sounds that work together. The next thing is a solid arrangement that combine the right sound for amazing impact. From here it pretty much the mixer job to bring sound to it's fulless potential. At this point if everything was done correctly. The mixer shouldn't have to do much work to get the song to work really well.
What that point of all this. I don't really know I guess I'm just ranting about nothing.
Thanks for listening and have a nice day.
A good mix is one in which you throw up the faders to unity gain and it sounds great. I start there. If it doesn't sound great in the first 30 seconds, another month will not make it any better. Turn off tracks and see what happens. A good mix AE knows what tracks simply don't belong. If you have 24 tracks, you don't need to fill them all up. You can't "fix it in the mix" or (my favorite) "fix it at mastering"
Good, solid tracks are essential.
