The Group DIY projects are well-regarded, but it's possible to do a tube pre for much less spread. The transformers are the expensive bits . . . so omit them!
Yes, I know, they would lynch me for that, but if you want to get started, you can go transformerless, and leave room for further growth as money allows.
The PRR Vari-Mu compressor has a VERY useful inexpensive PSU for a +150V plate tube plus +-15V supply for opamps (since we are doing a transformerless design, the opamps can be used as buffer stages), the heater is pulled from the +15V rail. That PSU design can be used for many different projects. I used it for my Peavey RAGE! mod.
So, if you are into doing your own design, take an existing schematic, replace the input and output trannies with opamps (find those schemos on the Jensen transformer--ironic, I know--or TI website--they have an opamp handbook), and you can probably do a stereo tube pre for $50 plus the box, knobs, meters, and such. You would need to do your own PCB, although I have a feeling the PAiA tube pre could be modded for full plate voltage fairly easily; that is a hybrid design . . .
Heretic! Heretic! Burn the heretic!
