solutionsagent
Hello,
I have been able to synchronize 2 pieces of gear easily with MIDI - setting one to Master and the other to Slave. I was wondering is there another piece of gear I would need to buy to sync more than 2 pieces?
I would like some advice to get my three synthesizers to sync. My goal is to record on some software like Cubase / Logic / FL Studio / Pro Tools or whatever is ideal... I want to record sequences from a Roland MC-909, have it sync to the measures on the software program, as well as have the other synths like the Korg Trinity and Roland JP-8000 sync to the MIDI tempo as well so that tempo delay effects or arpeggios are all properly timed. That way when cutting and pasting a measure in/out of the software, it cuts a perfect measure with the properly timed MC-909 measure and the Trinity/JP-8000 tempo delays and arpeggios.
I am thinking the Computer should be set to 'master' and all synths should be set to 'slave'? Can they all plug in at the same time or is there limitations?
Please suggest any hardware that may be needed.
Current Hardware:
PC 2.6GHz 1GB RAM
Roland MC-909
Roland JP-8000
Korg Trinity
Yamaha S-90
Tascam US-122 (USB Audio/MIDI Soundcard - I am willing to upgrade if needed.)
Respectfully,
SolutionsAgent
Current Hardware:
PC 2.6GHz 1GB RAM
Roland MC-909
Roland JP-8000
Korg Trinity
Yamaha S-90
Respectfully,
SolutionsAgent
) If so, you could daisy chain them. That involves connecting the MIDI out from your US122 to the MIDI In of the first device then connecting the MIDI Thru of that device to the MIDI In of the next device and so on. MIDI Thru merely passes the data from the IN directly out. This would limit you to 16 channels of MIDI data which would necessitate some planning in how you construct your sequences. You'd have to assign different channels to each synth.
