kanga said:
hiya nathan,
thanks for the feedback,
you've got a sharp ear, yes there was only one microphone in the recording but it was done with multitracking, and it was about a foot away from me the whole time,
do you think the drumming is actually out of time or just lagging behind? if the drumming itself is the problem then i've got an awkward conversation awaiting me with the drummer! if it's just lag i can fix that by shifting the track, but i guess ye would have suggested that!
three listens? you're a champion!
i've tried copying vocal tracks, adding reverb to one, but what exactly would be achieved by a 5-8k boost on the compressed one?
thanks again,
seán.
It's the drummer I reckon, or rather the drumming. Maybe a click and keep doing takes until he nails it would work.
There are a couple of reasons behind having two copies of the vocal track, one compressed and one reverberated...
The fact that the uncompressed take feeds the reverb, means that when you sing louder, the vocal sinks back into the ambience a bit, and becomes wider. Then, in the quiet bits, the compresser will keep it close to the same volume, but the ambience is gone, giving an intimate sound appropriate for this kind of part.
The presence boost on the vocal compressed vocal track adds 'excitement' and some clarity without having to be too loud. Just watch for sibliance, and make sure your mic doesn't have a boost here already, as some cheaper condensers have.
I often only use the compressed version of the vocal, along with the reverb return of the uncompressed one (or the uncompressed track is reverberated 100% wet 0% dry).
How you set you set the compressor is the main crux of this. You sound like you have some dynamics going on there.... Try a ratio of 8:1 with a threshold that ensures the comp does nothing on the quiet parts. Medium attack, Medium release. What compressor are you using ?
If you are using a large diagraphm condenser, put the tip of your thumb on your lips, and strech your hand as much as you can towards the mic...you should be able to barely touch the mic with your little finger.
Use a pop-filter, and put the mic above your mouth, facing down. This avoids some nasal sounds, and causes you to tilt your head up slightly opening your vocal chords more.
Hope this helps.
Nathan
