ipad recording
  • Thread starter Thread starter dolecekq
D
dolecekq
I'm using the ipad 2 air for recording. It has some killer daw's. Anyway when recording my signal is way too hot. For my amp sim I'm using bias-amp. I have tried turning down the input/output in bias but ztill i have an enormous signal so its distorting horribly. The signal without the daw is perfect. It is only when i load the daw. I have even turned off the internal mic for the app, but the mic muted wont work because the program required that internal mic which is weird to me because 9t doesn't really use the mic, its more like recording direct, i have tried other daw's and I have the same issues. Hoe would I fix this so I can do some recording? and thank you in advance!
