C
chicken gutz
Just bought an Alesis IO26 after using the MultiMix 8 Firewire for 6 months (I needed more inputs), and having set it up to record my 7 drum mics, I find I need to max out the faders in Cubase to get any volume at all on playback.
The preamps on the IO are set so that the level meters on both the IO and Cubase bounce into the yellow just shy of clipping when I play as loud as I can.
None of the above have made any difference.
Also, when I monitor my guitar through headphones, I only get a left channel. The problem is unrelated I'm sure, but I thought I'd tap the resource here for a suggestion.
Thanks in advance!
- All drivers are current.
I've tried using the AC adapter instead of powering through the firewire card.
I've set the default playback device to the IO.
Thanks in advance!
