pianoman1976
Hello friends,
Maybe "integrated" is not the proper term. What do you call, for example a Digi 003 setup which has software (Pro Tools LE) designed specifically for the hardware?
I had almost decided on a Digi 003 (For use with a iMac C2D) until I did a bit more research. I like the simplicity of the 003. I like the idea that the software is designed around the hardware - this seems to be a seamless trouble-free approach.
I am now leaning more towards an RME Fireface 800, simply because the audio specs seem much better. What about software for this thing? I liked the idea of Pro Tools LE, because I'm a newbie. Can I use PT LE with this interface? I'm in no way capable of tackling Logic. I wish there was an "LE" version of logic for the new guy. I'm fishing for ideas and info about this.
Most importantly, I'd like to know if I'm looking at more complexity by not going with an integrated solution? Might there be set-up, software/hardware and/or compatibility complications that I would avoid by going with the Digi 003?
Thanks,
Ryan
Thanks,
Ryan
