six
ok, ok, muttley... I read it again and had to realize, it's actually not much that is said, and the bit that is said is of course true. but it's so damn sexed up that I got distracted by the fillers.
Nevertheless, I'm still convinced of three things that do not contradict this article:
1st - Tuning your guitar by using open strings and tuner you can pretty much do without the knowledge of tempered and non-tempered intervalls and the tuning method mentioned. You'll stay in the tempered world.
2nd - If you don't have a tuner, you can use the beginner-method (which doesn't rely on harmonics) and you won't leave the tempered world either.
3rd - The whole knowledge about tempered and non-tempered intervalls, scales or instruments doesn't solve the OP's problem, which is very obviously a wrongly set up or - worse - built instrument.
Read http://hubpages.com/hub/Equal-Temperament-Guitar-Tuning under "Testing your instrument":
"[...] but if every stopped string is equally sharp (or flat), you may indeed have an ill-made instrument. [...]"
