Interface option
  • Thread starter Thread starter rose62
R
rose62
A friend at work has an Alesis MultiMix 8 USB FX. Will that work as an interface with Reaper?
If you just want an interface there are better, more current pieces of equipment. According to the table at Sweetwater, this only supports USB 1.1 (slow), and 16-bit/48kHz. You really want at least 24-bit and USB 2.0. Its USB connection is only stereo, as well, and not full track support, so really, this is a mixer first, with older USB support tacked on, IMO.
Yes, you could use it, but unless you have a real use for a mixer (i.e. live shows), using an audio interface will give better recording and monitoring ability.
If you are looking for a (new) audio interface: what is your budget? What is the maximum number of microphones/inputs you anticipate ever needing? PC or Mac?
No, MJB, I already have an interface. But a buddy at work, who is an excellent drummer, has the Alesis unit and I thought that if he bought the Reaper software, he might use his Alesis to lay down some drums for me. I could put the tracks on a portable memory device and he could simply load what I had done to a comp and, using the mixer, lay down some beats and he wouldn't have to buy anything else.
It would likely work for what you are planning, but keep in mind you would be getting his stereo mix of the drums, and not a nice set of 4 or 5 or more drum tracks you could mix in.
It's not a terrible way to get drums though, and [with an AI] you'd only get more, usable tracks assuming he's actually got a bunch of mics to set up and either knows what to do or takes time to learn. (I've recorded some friends with a cheapo electric kit with only L/R out and it's been a good place to start.) But, if you get stereo tracks, you'll probably have to do some EQ, compression and panning, and hope he's not some mad cymbal banger who's never recorded himself before. With only stereo, or a couple mics, the drummer has to usually behave a little differently than live. And then, there's the room where he'll be recording...
I'd give it a try while you're deciding, especially if he's got mics and used to micing his kit (maybe why he has the mixer?). But, for your purposes, it also might be as easy, or even easier, to plug a digital recorder with line-in capability into the mixer and just take the stereo analog files and drop them into your project, and let him drum away while listening to your tracks. Just a thought.
