studiomaster
I'm interested in the Apogee converters...
chipwits said:Would like to hear comparison with some cleaner source material though =P.
chessrock said:I'd be open to something else if anyone has any ideas. I'm certainly going to be posting some comparisons with the samples NL5 is supplying me, which could give a different perspective I suppose.
chessrock said:When I tried removing the tube, there just wasn't enough gain on the thing...
ermghoti said:My Compy peed the carpet a couple weeks back, so I wasn't able to listen. Wah. Mostly fixed now, but there's still a chalk outline where AVG used to be.
Anyway, I hear a persitent claim that a DI/O makes a really decent converter, if you remove the tube (not turn it down, unplug it) and use a much higher current AC adaptor. For instance.
I use one with the tube pulled, it does OK, and I keep meaning to dig up a stronger adaptor. Maybe a little blind taste test might help me decide if it's worth the trouble...
OK, that was a big "unless"
ermghoti said:Dunno. It bears repeating that the output drops big-time after pulling the tube, perhaps the amperage merely jacks up the output, appatently at the expense of greatly increased heat, if Chess' experience is typical.
. . . well, that's kinda the pot calling the kettle black
) would have a similar effect.Stefan Elmblad said:Came into this thread when the answer was already posted, but I'd like to point out the fun if you add another file to the contestors, that are an exact copy of one of the others. Makes people listen harder, can say alot about some opinions people have.
amra said:I guess I suck.
I couldn't really hear any appreciable difference between the samples, with the exception of the original.
Oh well. Too many shows in front of really loud amps, I guess.
