insulation
  • Thread starter Thread starter LDQ
L
LDQ
Hello all,
On the attached drawing....is the 50 mm insulation for the floor and wall rigid or regular insulation? Do I have any options as to which type I use?
Let me know,
Cheers,
Luis
Unless $$ is no object, regular insulation is sufficient in both cases. And if that's an external wall , make sure you have a vapor barrier beneath the drywall.
Thanks for your response Dan....
This would be for my basement wich is concrete floors and walls. I want to make shure I have good isolation and don't freeze to death in the winter.
What regular insulation do you recomend?? Can I also used ceiling tiles fiber board....you know cheaper than that 703 and Knauf stuff.?
Regards,
Luis.
I guess you can use the fluffy kind of rockwool/fibreglass batts in there.. My Master handbook says (4th edition, page 172):
"The low-density mineral fiber batts commonly used in building construction are as affective as the high-density boards, and they are much cheaper."
Herwig
